928 Forum 1978-1995
Sponsored by: 928 Specialists
Odometer problem
Old Jul 9, 2018 | 10:39 PM
ScottMRandolph's Avatar
ScottMRandolph
Default Odometer problem
I worked through the write-up on how to replace an odo gear (was "fiddly" indeed Wisconsin Joe), I could see reddish/brown crumbs (disintegrated gear), but looks as if the gear detonated the housing, shearing off the "ear" that the circlip and "pin" attachment point, At this point, (not having researched replacing the white plastic housing), guess it comes down to how much I want to pay (time and money) to get a functioning odometer. Might be best to clean and seal back up and move on.
Housing with the "van Gogh" treatment
mmmm, toaster leavings!
Scott
1984 928S GrandPrix White
Old Jul 9, 2018 | 10:45 PM
AirtekHVAC's Avatar
AirtekHVAC
I’m sure you could get a reasonably priced used “core” housing from 928 Intl...
Old Jul 11, 2018 | 10:31 AM
ScottMRandolph
Thanks Ron, all I am finding are rebuilt or new Speedometers - $400 - $850. Am still searching, I found the broken off piece of white plastic, but not sure I will be able to bond it back in place well enough.
Old Jul 11, 2018 | 11:25 AM
Wisconsin Joe's Avatar
Wisconsin Joe
Oh my. That's a bit of a mess.
Option 1: Fix it. I would take the broken pieces, cut a groove around the outer perimeter in the pieces and the 'base'. Then epoxy (I like JB Weld myself, but others are good too) the pieces together, along with a wire going around the outside (in the groove you cut). That will act as a reinforcement and will strengthen the joint.
Option 2: Call Mark or Tom at 928 International. As was suggested, they likely have a 'core' speedo that would simply be the white plastic housing. You would have to transfer all the guts from yours over.
And yes. "Fiddly". I was not kidding.
I have a fair amount of experience in scale models and gunsmithing. I have a decent collection of small pliers, jeweler's files, tiny screwdrivers, miniature clamps, hemostats and about a bazillion pairs of tweezers.
Stuff like the speedo/odo, the lock cylinders, seat belt retractors, wiper motor and that sort of thing are a challenge, but something I am pretty good at.
Old Jul 11, 2018 | 12:40 PM
ScottMRandolph
Indeed it is a mess Joe, appreciate the suggestion of adding a wire for stability. No "core" available from 928 intl according to Tom. Time to add a magnifying glass to my toolbox.
Old Jul 11, 2018 | 02:25 PM
GT6ixer's Avatar
GT6ixer
Hey Scott. I have a used speedo that came out of my '84 in very good condition for sale ($250). It is a KPH unit but you could use as a core. PM me if you are interested.
https://rennlist.com/forums/parts-ma...eedometer.html
Old Jul 11, 2018 | 03:18 PM
ScottMRandolph
Thanks Nate, will check it out.
