928 headlights not coming up
hi
my headlights are coming on, but not moving up. They come down automatically without issue when the lights are turned off. Any ideas?
thanks
thanks
First check the connections to the motor. Check to see if they are clean and have a solid connection.
Then check the relay to see if that is still working correctly. It it is original it may have failed. Swap it with a known good one or plug yours in somebody else's car to check it.
Lastly check the motor. I had one fail on my 89 where it would keep going around until it hit the condenser because the contacts inside had worn out.
