Did some googling and found Xpel carries a pattern.DescriptionInfoInfoAdd To CartHood and Fender Kit
Difficulty Rating : p2505-U
$199.95 Add To CartBumper Kit
Difficulty Rating : P2505C-U
$419.95 Add To CartHood, Fender and Mirror Kit
Difficulty Rating : 18 inch bikini cut P2505D-U
$269.95 Add To Cart
Cool, when I searched I found nothing. I actually just had Xpel ceramic tint done and they told me there was no templates for the windows either. I guess they were wrong.
It wasn't that hard. Only tricky part was cutting in reliefs at the inner corners of the driving & fogs (pre-87)...hardly noticeable unless your staring at it up close. Film is put on wet with soapy water so if you mess up, just slide it around a bit to where you need it. Don't start cutting until you have it lined up and if you mess that up it's only another $50 and lesson learned. Had the FBC on the 991 professionally done and it was $ 500 (and the pro cut in some reliefs) so decided to try this myself. You can do this ! Video's all over YouTube, ex:
