Correct way to close up the CE panel in a GTS
Tried search but couldn't find anything.
The plastic pins circled in blue, do those pins go inside of the side carpeted cover that is to the right, or do they stay outside of the side carpeted cover? Anyone know the purpose of those pins?
And lastly, that plastic strap enters through the bottom of the metal hook, right? It seems kinda obvious but just want to make sure. Don't make fun of me, lol.
Thanks in advance!
Thanks in advance!
The carpeted computer cover absolutely has two corresponding holes the pins slide in to.
Pictures may help
Appreciate all the replies!
Thanks for the pic Kevin, that was helpful! Pins definitely slide into the cover. Here's a pic of the backside of the cover where the pins slide into. Didn't even notice that till I saw your pic.
Electron Wrangler
On a later car there are alignment holes - pretty obvious where the pegs go then!
The strap goes through the metal hook/clip after it clips the top of the cover in - I thought it only really reached one way...
Alan
Alan
This applies to everything, not just 928s
2nd pic in post #1 is pretty close.
Just pull the tip of the strap down and feed it up and under the metal 'hoop'.
It should end up pointing straight up, going under the metal.
Chronic Tool Dropper
The strap on my '89 goes up under the metal hoop, then loops back and passes under again, ends up pointing down and exposed on the outer face.. As shipped.
