WTB: oil filler baffle
In addition to that part you're looking for, I also installed Precision Motorwerks Oil Filler Neck Baffle when I did the upper refresh.
Adding the second baffle has stopped the pools of oil I used to have in the air intake side manifolds. I figure by doing this I'm better protecting the wire in the MAF.
http://www.precisionmtrwerks.com/products/products.htm
Eh...I'd argue that part does next to nothing, and Porsche didnt realize the scope of the problem at that time.
A proper baffle, not just this splash grate, is what you want.
hurt. that's why I am searching for one.
Archive Gatekeeper
Whoomp, there it is.
only wish I could find those red handled pliers and yellow screwdriver handle that fast!
Maybe air flows in reverse thru the engine when the gearbox is on reverse? ;-)
More seriously, alternating between WOT and throttle closed at various rpms might spray some oil out of there as well, if the whole zip-tube throttle-body element (I'm thinking S4) is filled with oil. Shouldn't be much, though.
