Help with brake booster hose routing
Lili's engine is in, and I'm replacing rubber hoses everywhere. The diagram from the parts catalog PDF I have (years 78-82) #604-00, shows the parts associated with the brake system: MC, booster, etc. In the diagram, two hoses, one 650 mm and one 50mm, parts numbered 15a and 15b, exit Y fitting, number 28, at each straight end of the Y. Where do those hoses attach? It looks like 15a connects to the back of the aux. air regulator. Is that correct? Where does 15b connect?
James
James
Team Owner
15 a connects to the left top of the spider body between cyl 7/8 intake tubes. This is a hose about 2 inches long.
The 15b wraps forward to the front bottom of the intake body,
it will feed into the lower front from the left side of the intake manifold between the 5/6 intake tubes
Team Owner
Team Owner
Your welcome James.
NOTE this picture is not from a 1979 but the 15 a/b hoses you asked about are pictured
