Not sure what ball joint's I need
I need to replace the lower ball joints not sure at first what I have either the later style or older after some research I figured it out I have the older style. And of course there way more expensive.
Team Owner
your good on those BJs those are the steel versions post a picture of the eccentrics .
NOTE. going from an aluminum BJ to the steel version requires one of the eccentrics to be swapped out.
If you have doubts get a magnet and touch it to the BJ body , if it wont stick then its aluminum.
Best thing to do look up click on user CP and scroll down to edit signature,
put the year and model and trans type into your signature
