928 Forum 1978-1995
Sponsored by: 928 Specialists
Ball size
Old Mar 11, 2018 | 01:43 PM
gazfish's Avatar
gazfish
Default Ball size
Hi,
I took my fuel test port cap off to measure the fitting size, and have been struggling to get it to seal again.
Checked PET and it shows a steel ball is supposed to be in there, I was careful when I removed the cap and nothing fell out but maybe I'm wrong.
It's cheap to buy the porsche part but adding postage makes it nuts, can anyone tell me what diameter it is as I've probably got one lying around I can just throw in?
Thanks,
Gary
'86 Euro S2
Old Mar 11, 2018 | 02:23 PM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
9mm.
Old Mar 11, 2018 | 02:35 PM
Adamant1971's Avatar
Adamant1971
Originally Posted by gazfish
Hi,
Thanks,
Gary
'86 Euro S2
Have you tried a thin coating of Loctite 574 on the ball?
I'm doing the same today but to check pressure and need to go out and purchase a guage. What was the fitting size?
Old Mar 11, 2018 | 03:02 PM
gazfish's Avatar
gazfish
Originally Posted by Rob Edwards
9mm.
Perfect, thanks Rob
Old Mar 11, 2018 | 03:04 PM
gazfish's Avatar
gazfish
The ball is missing completely, I've managed to seal it temporarily with plumbing gaskets and tape. The thread diameter is 12mm. It seems to be a choice of 12 or 14.
Old Mar 11, 2018 | 03:44 PM
mkriete's Avatar
mkriete
A similar size ball will work, if you can’t find Te exact metric size. I think mine is slightly larger. Seals fine.
Old Mar 11, 2018 | 11:51 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
whats more important is where is the old ball?
look carefully it would suck to get it into the belt run.
FOD... must always account for every part/ tool /rag/ cover
