No abs or brake pad warning lights.
Hi folks.
The restoration of my daily drive 87S4 continues.....
My question today is :
I don't seem to have any warning lamps for the Antilock, Brake fluid, brake pad or Engine oil, but i do have Parkbrake, when i turn on the ignition.
The bulbs in the cluster seem ok so what else would cause this?
I have all the correct warnings on the temperature /,fuel quantity side.
Kind regards.
PS Here is a picture of my pride and joy..
Martin
Kind regards.
Martin
Central Warning Light
Hi folks.
My Central warning light was missing from the instrument cluster so i replaced it and it works fine apart from when the car is turned off and the key removed ,the warning light stays on!!!
Any ideas?
Martin
Any ideas?
Martin
I didn't replace the central unit, just the bulb that illuminates red.. All the connectors are connected properly as the instruments work fine. After replacing the bulbs on the oil pressure/voltmetre side, the missing Antilock, Brake fluid, brake pad or Engine oil, lights now illuminate..good news.
Just cant get the light that lights up in red the "I" symbol to go off when the car has been shut down.
