Who's the U-Boat commander?
This guy!
No, seriously. The river's coming up due to ice jams and Stitch decided to throw his alternator belt. I put it back once, and he did it again. Running rough, probably due to low battery.
It's still unknown how high the river's going to get, but I may have an aquatic shark by the time it's over.
Shameful Thread Killer
Weird, last time I was in the Pok-yer-nose, it was up in the mountains. Get some blocks, and get it up off the ground.
Happily: Non-issue. The river, which was set to a worst-case scenario of a 35-foot crest - which would have put water in my basement and maybe up to the floorboards of the car - crested at 28 feet. The ice jams broke up and flowed down toward the Chesapeake, and all is good. The water got into the street that runs along the river, but no closer than a block or two from me.
Now, to figure out what the hell with the alternator belt. I drove the car from here to Frenzy and back with no problems. I go to start it and it throws the belt. Weird.
A problem free long trip, a flood scare with a happy ending, then the belt thrown in your driveway the next time you start it? What the hell is up is some great karma...and probably some loose bolts.
Does the '82 have the ribbed alternator belt like my '86, or is it a v-belt? My car started throwing it's power steering belt a while back...it turned out to be a bad belt...the backing, or whatever you call the outside of the v-belt, had cracked, so it had no structural strength there. Not sure that could happen to a ribbed belt though...
Glad to hear you dodged a bullet Shawn!
Looong ago, my thrown alternator belt was the diagnostic clue that led to the discovery of the mount whose upper end had been violently broken straight out of the block by an alternator strike on a smooth Texas road. I hadn't really noticed when it happened at about 75mph. There's a reason nobody's ride height should be 125mm in front. ;-(
