Stumped by Flasher
Nooooooo.....the signal flasher. 1988 S4. The hazards work, all turn signals work. As soon as you turn the car on the turn signal light is going off on the dash (but not any outside lights). I swapped the relay. Same deal. Anyone? I'm stumped. All the dash warning lights are out. Marye something in the suspected shorted pod circuit board is causing it?
Thanks,
JE
$5K 1988 S4 coming back to life slowly but surely.
1986.5 928S for sale at fire sale price (no place to park em all).
Thanks,
JE
Originally posted by JE928Sx4
Nooooooo.....the signal flasher. 1988 S4. The hazards work, all turn signals work. As soon as you turn the car on the turn signal light is going off on the dash (but not any outside lights)... All the dash warning lights are out. Marye something in the suspected shorted pod circuit board is causing it?
John,
Will do. Didn't toss any relays. It went back to spares stash.
Mike,
I figure it's something back there as well. The pod is coming off tomorrow for a full investigation so stalk switches and everything else will be checked as well.
Regards,
JE
Mike,
Regards,
JE
Originally posted by John Struthers
JE,
You have me curious... let us know if was that fuse.
If that's the problem I hope you didn't toss the relay.
JE,
Originally posted by MikeN
You might want to check the turn signal switch connections behind the steering wheel also.
Could be something in the pod, but I think something is actually sending it a signal to flash.........
I don't know. Probably, I was a bit young when she was putting out ****.
JE
JE
Originally posted by Jim bailey - 928 International
John the title of this thread ......was that not also a Marilyn Chambers film title ?
