PKsnr alternate tension release question
Hi Guys,
I'm about to tear down the front of my supercharged 16V Ljet, to fix a timing belt that I installed one tooth off on the DS cam. I have a PKsnr, and would like to release the belt tension without removing the center TB cover. I'm not sure I can get to the idler pulley mount to release tension in the usual way, but it looks like I could loosen two of the three tensioner mounting bolts, and let the tensioner pivot in order to release tension. I figure I'd then remove it completely, compress it and then insert a pin before reinstalling. Does anyone with experience with this device have any advice.
Thanks in advance,
Dave
Thanks in advance,
Dave
Hi Guys,
Thanks in advance,
Dave
Thanks in advance,
Dave
I removed the stock tensioner on my 16v without removing the centre cover, I did clip a corner off to make access to one bolt a little easier.
Hi Guys,
Thanks in advance,
Dave
Thanks in advance,
Dave
Inventor
I have done the swing-away method many times.
When compressing the piston off the car, use a big C-clamp (held in a vise) to push the piston vertically. It will push in a few MM then stop, wait (up to 30 secs cold) then continue pressing until the pin can be inserted.
More info:
https://www.blauparts.com/audi_timin...tallation.html
More info:
