PS pressure hose: new, used, reman?
not sure why, but my PS pressure hose from pump to rack was "leaning" against the exhaust manifold
and burned thru the hose. should I replace with brand new, good used, or take to a local hose shop to have them remake it? also, this does not look like fun to replace? is it as much of a PITA as it looks?? |
Any good hose shop should be able to re-man it for you. Just make sure they re-use the inline flow restriction and install a new piece of heat resistant sleeving. Don't install a used one as you could get that complete only to have it rupture the next day and burn the car to the ground. Changing it out is relatively straight-forward once you drop the alternator out of the way.
Mike |
[QUOTE][re-use the inline flow restriction and install a new piece of heat resistant sleeving/QUOTE]
I understand the heat sleeve, but what is the inline flow restriction? something inside the hose? also, what's this burn the car down stuff? don't like to hear that story??? |
Originally Posted by merchauser
(Post 14697054)
As already suggested, get a new or remanufactured hose. |
And you need to address why the hose was out of position. There are a couple of plastic body clamps the secure the hose to the body.
Kevin, it was too hot to check earlier but it doesn't appear that the fittings at either end are loose, but
those fittings determine the orientation of the hose. Mike, what is the inline flow restriction? |
Originally Posted by Kevin in Atlanta
(Post 14697130)
There is a Little metal fitting in the middle of the hose. That is the restrictor. You need it. If you have the hose rebuilt the hydraulic hose place you use should be able to rebuild it for you.
Originally Posted by hwyrnr
(Post 14697507)
After the rebuild I examined the hose I removed carefully and could find nothing obviously wrong anywhere but preemptively replacing it is the way to go without doubt. What I did find was that the lower pressure/return hoses were in pretty poor shape. The change out is a little fiddly but not too difficult and you need new crush washers for the banjo bolts. One of the low pressure hoses was a little problemmatical in that the size of the fitting was different from one end to the other or so it seemed but I had hose of either two or three different sizes to play with. The problem I did have was that the shop doing the high pressure hose for me unknown to me deformed the fitting at one end slighly and no way was that thing going to bolt up. When I took them to task technician told me what he had done and cold pulled it back slighly in a vice- that solved the fitment issue. You also need to make sure that when they fit the hose end connections they do so at the correct orientation of the fitting. I simply looked along the axis, made a note of where on the clock face the fitting sat relative to the other end positioned at 12.00 as it were- cannot remember the numbers but it is critical to note and check that before you hand the piece in for working and make sure they understand this [which they probably will]. |
Fred's correct. There is no restrictor at that location. It is merely a location part to keep the anti rub grommet in place so your hose doesn't rub against anything in that local.
thanks for the clarification about the hose.
got the hose out threading it downward nearest the rack. on install, it will be a challenge to get the banjo bolt started at the pump. thinking if I drop the oil cooler lines, I might be able to get my fingers in there. otherwise, will be forced to drop the alternator. |
Drop the alternator, way easier than messing with the oil lines. Good opportunity to clean in that quadrant of the engine compartment.
Does anyone have a photo of the plastic clips and their location? I do not seem to have them.
Does anyone have a photo of the plastic clips and their location? I do not seem to have them. |
