Clutch arm ball cap bushing install tips
So I'm having no luck getting the bushing on the ball by itself or the arm on the ball with the bushing in the arm. I have heated the bushing up with a hair dryer hoping it would become pilable enough to go one easier, but no luck.
I just tried leveraging the clutch arm with a pry bar, the clutch disengages but the arm won't go on the ball.
Any tips or tricks?
89 Euro
Any tips or tricks?
89 Euro
Team Owner
get a dremel and a small sanding wheel open up the inlet ridges, you dont need much.
Then toss the bushing into a cup of very hot water, let it soak for a few mins,
then put a dab of DC111 into the bushing,
then put it on the ball,
gently pry it on .
The opening of the bushing is made so it wont come off the ball when you remove the release arm.
NOTE the pressure plate should also have the 3 spacers installed to give the release arm that last bit of clearance to fit over the new bushing
gently pry it on .
gently pry it on .
gently pry it on .
Team Owner
the spacers are needed to fit the arm on the bushing, BUT a third hand up top while fitting might also work
Done.
I ended up removing the ball, used the hot water trick and pressed it on. Put the spacers back in (one was all I needed to get the extra clearance), and I got the arm on without much fuss.
Now this car's drive line is done, on to the AC system and cooling system.
Team Owner
Cool , Keep em flying!
