Tie down points?
Tie down points?
OK - now that I have decided to trailer my 928 from CA to VA- does anyone have any recommendations on tie down points? I really don't want to arrive at my new home with a tweaked suspension due to my own stupidity Recommendations and/or pictures would be most appreciated - I know for a fact Santa will guarantee you a spot on his Good list!
Bill
Bill
Recollection may be inaccurate, but my last (Tilden) twin axle rental had sliding 'chocks' to secure the wheels fore/aft plus ratcheting web strap tie-downs that went over top of each tire: when 'ratcheted' tight, the chassis was still freely suspended. Worked great - for an Audi Quattro; now for a 928....
In front there are two factory tie down loops. You have to look up above belly pan level, but they are there. I went to the hardware store and picked up four screw closed type links. They look like big chain links but you can screw them open on one side. I use two on each side and run a strap through the bottom one. In the back, I screw in the tow eye and run a strap through that. I don't tighten that one too much and it may not be the best for a long trip.
