928 Forum 1978-1995
Sponsored by: 928 Specialists
Clutch Slave Cylinder Rebuild
Old 11-22-2017, 09:17 AM
mskar
mskar's Avatar
Default Clutch Slave Cylinder Rebuild
I pullled my clutch slave last night and thoroughly cleaned and rebuilt it with a new seal kit in about an hour. Spent the next 3 hours trying to get the piston back in. No matter how carefully I push and tuck, the seal ends up bulging and blocking my progress. For my last try I put the piston and seal in the freezer for a couple of hours and tried again. I have left it in the freezer with a zip tie around it to try to shrink it and will have at it when I return from Thansgiving but does anyone have any tips for getting that thing back in? I’m betting there is some slick little tool that a hydraulic shop would have like a piston ring compressor, do I need a tool? Thanks and Happy Thanksgiving everyone!
Old 11-22-2017, 09:37 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,257 Likes on 1,250 Posts
it sounds like you have the wrong seal, the correct seal will slide easily into the bore,
as the bore has a bevel to assist its insertion
Best to use ATE gold fluid
Old 11-22-2017, 11:31 AM
buccicone
buccicone's Avatar
Hmm. In my only attempt to rebuild a slave, I couldn't get it in either. Ended up tearing up the seal. Gave up and bought the $400 new piece.
Old 11-22-2017, 04:24 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
do you have the part number for the seal kit?
Old 11-22-2017, 05:43 PM
mskar
mskar's Avatar
I’ve left town at this point so I’ll post the part number when I get back. I ordered it from Roger and it would be unlike him to fill an order with an incorrect part. The seal looks pretty much the same as the one I took off, it just puffs out on the split side (cylinder side) presumably because its new. I’ll check on it when I get back tho!
Old 11-28-2017, 12:38 AM
mskar
mskar's Avatar
Looks like I received part # 928 116 901 00, which cross-referenced definitely looks like its for 83-86. I've contacted Roger to see if a later kit exists but I have not seen one anywhere else. So a couple of questions:
1. I'm assuming this is another "in-tank fuel pump" situation where the price of a part goes from normal (porsche-normal) to obscene because we're down to a single manufacturer?
2. Is the 83-86 clutch slave interchangeable?
3. If it is not directly interchangeable, and the difference is rod length, could the rod off my current clutch slave be swapped over to a new 83-86 body?
4. If none of the above, does anyone have a recommendation other than spending $500 on a $50 part? Is there a rebuilder out there that people are using?
I had planned on hitting a couple of hydraulic shops around the area to see if someone could get me a seal that fits my slave but I ran out of time today.
Thank You!
Marc
Old 11-28-2017, 10:28 AM
merchauser
merchauser's Avatar
White Post Restorations does great work with lifetime warranty. I have used them many times
http://whitepost.com/brake-sleeving-...ding-services/
Old 11-28-2017, 01:09 PM
ROG100
Basic Sponsor
ROG100's Avatar
PET list that seal kit for all years up to 95. It is possible that PET is incorrect.
Old 11-28-2017, 03:35 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
it would help if you could post pictures of the old and new pistons and seals maybe the new seal has a smaller ID and this is pressing the seal outwards?
Old 11-28-2017, 03:54 PM
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
I show that both are 22.2mm but I don't see that seal kit in PET for the single disc clutches
Old 11-28-2017, 04:11 PM
ROG100
Basic Sponsor
ROG100's Avatar
Mark shows on PET 301-05 below item #14 all the way to 95
Old 11-28-2017, 04:15 PM
Mark Anderson
The Parts Whisperer
Not on PET 6.
Old 11-28-2017, 04:18 PM
ROG100
Basic Sponsor
ROG100's Avatar
I am on PET 7.3 PLUS update 433 - I sent you a screen print.
PET 6 is that on the ark still? 8>)
Old 11-28-2017, 04:21 PM
ROG100
Basic Sponsor
ROG100's Avatar
In this thread two people have said it does not fit - could be a glitch on Porsche's side of course.
Shame it does not fit as the other stock alternative is to replace with the $489 slave.
I sent Marc an 86 slave to see if that can be made to work with the later rod.
Old 11-28-2017, 04:57 PM
Jim Devine
Jim Devine's Avatar
Try these guys- they are the same company that did the seals for the psd slave cyls a few years ago. Contact them- may have to send a sample or the piston & cyl
scroll down past the table of contents-
https://www.physics.harvard.edu/uploads/files/machineshop/epm_oring_handbook.pdf
original thread on psd slave cyl seals- seems they have the capability-
https://rennlist.com/forums/928-foru...r-options.html
Quick Reply: Clutch Slave Cylinder Rebuild
