clutch slave cylinder
Anyone had luck with rebuilding the slave clutch cylinder on '87+....I have one leaking & one I replaced a few years ago...or is this a waste of time & $ ? I realize the condition of the bore would dictate whether it would be successful, What about longevity??
Tom Taylor
Tom Taylor
I have had good luck with White Post Restoration and they offer lifetime warranty!
http://whitepost.com/brake-sleeving-...ding-services/
I think the new OEM clutch slave is pretty expensive.
Received 1,542 Likes
Administrator - "Tyson"
Recently had them rebuild a clutch master. They sleeve the bore so original conditions is irrelevant and the sleeve makes them longer lasting compared to original.
Team Owner
you can also see if 928 INTL has a used 87 on slave .
NOTE S4 on are longest slave cylinders,
if you put in an 86 version the clutch wont release properly as its a bit shorter.
In the picture you can see the Greg Brown slave flex line connected to the shorter ( wrong slave) cylinder.
Note this was in my car when I got it and why the clutch went bad, It took a bit of sleuthing to figure this out
[QUOTE][Doesn't seem to expensive to me.
http://www.pelicanparts.com/More_Inf...M33&SVSVSI=999/QUOTE]
that is the earlier model slave for <1986. the part number for >1987 is 928 116 237 22.
usually north of $500.
'87+ can be had for just less than $300. However, the last time I needed one it was ~$90.
Team Owner
yes it was 90.00 till they sold out,
then a 5 month time of no slaves available,
now back in production and the supply lines being filled, still 300 for a slave cylinder is a rook job .
you can buy a toyota slave for 24.00 ,
yes I know it wont fit but still thats the idea its just a slave cylinder.
Team Owner
just go to the web site and call that vendor,
then you can send in all your old MC and slaves and have them redone for a group rate
This also alleviates the issues of piston length since you are getting the same one back, just with new seals and an upgraded cylinder.
Cost:
Brake / Clutch master: $225
Slave: $175
Brake Master & Booster - he will only do a booster with a master as a package: $470
He stopped rebuilding boosters separate after receiving some back under warranty only to be full of brake fluid from the master leaking. The only way he can warranty such parts is to do them in pairs. So if you plan on having a brake master rebuilt, might as well send in the booster.
Cool. Thanks H-P.
