928 Forum 1978-1995
Sponsored by: 928 Specialists
CE Fuse & Relay Panel
Old 11-19-2017, 03:55 PM
polecat702
Vegas, Baby!
polecat702's Avatar
Default CE Fuse & Relay Panel
Are the fuse and relay panels year specific as in the panel for my 89 can't be swapped with another panel other than another 89?
Old 11-19-2017, 04:23 PM
Alan
Electron Wrangler
Alan's Avatar
Almost all years are different - so generally match to the year - for a 1989 there is no other equivalent. Technically you need the exact same panel number (embossed on the panel) - always worth double checking that.
Alan
Old 11-19-2017, 06:45 PM
polecat702
Vegas, Baby!
polecat702's Avatar
Originally Posted by Alan
Almost all years are different - so generally match to the year - for a 1989 there is no otter equivalent. Technically you need the exact same panel number (embossed on the panel) - always worth double checking.
Alan
Thanks Alan,
You're the expert!
Old 11-19-2017, 10:10 PM
ammonman
ammonman's Avatar
If you need some generic bits for your CE let me know. I have a spare that I use as a parts donor.
Mike
Old 11-19-2017, 10:52 PM
polecat702
Vegas, Baby!
polecat702's Avatar
Mike
Thanks Mike, I'm still investigating.
Old 11-20-2017, 04:23 PM
nosnow
nosnow's Avatar
I have been down this route on my 86. The CE panels are specific to year, you want to make sure the one you put in is the same as the one you took out.
Quick Reply: CE Fuse & Relay Panel
