ID radiator side tank fittings
I would like to locate a hose-end fitting for an S4 radiator side tank.
The four ball-end type fittings on the radiator (two for transmission & two for engine oil) are all of the same type and are fitted to the radiator with what seems to be a 22mm - 30mm (ball) adapter union.
I would like to locate a straight-in fitting like the bottom transmission line fitting, but do not know how to identify this type of fitting.
Alternatively, identification of the radiator entry fitting might help.
Find a hose from a -86 auto car. Earlier cars from 82 back definitely have the hose you are looking for.
Buy the old used hose and harvest the connector. They run under low pressure so you can use a clamp to hold the new hose on or have it crimped by a hydraulic shop.
