Turn signals not working after removing aftermarket alarm
I have removed an aftermarket alarm system, everything is now fine except turn signals are not working. (they were fine before...and somehow connected to the alarm and central locking remote which were part of this system)
Now, when I move the turn signal lever, the green light in the pod lights up green, but not flashing, just steady green until I center the lever again. No turn signals lights up at all. Same to both sides.
When I press the safety hazard switch nothing happens, no green light in dash, and no turn signals.
Anyone with a suggestion to where the culprit probably is? As far as I can remember I found no cut wires, only spliced ones that I have removed. Fuse checked ok.
92 GTS btw.
92 GTS btw.
I guess you are right Stan, thanks for bothering answering Will see what I find. Any Idea which of the lower wires that has anything to do with turn signals? Is there some kind of understandable wiring diagram of this? Understandable as in not used to reading wiring diagrams...
