After trying to find a parisitic leak car will start but wont run
Okay trying to find a battery drain I disconnected all the harnesses and relays and fuses at the CE to no avail. I reconnected everything and now the engine wont run it starts while the starter is engaged then dies. It ran fine before. Can someone post relay photos for a 82. maybe I Transposed two relays I don't know. It starts with fuel and ignition then stalls in three seconds when the key is released. It ran fine before I tried to find the battery drain. I think the fuel pump relay might be compromised. I need a photo of the the CE with all the relays in place including the relays that are not the simple 85 style.
