More on headlight alignment.
I found that the lights have a fore/aft <---> alignment relative to a ground.
Do they also have an up/down adjustment as well?
Not a rotate up/down, but again relative to the ground.
Im fining that the base of the lights are contacting the fender at the front of the headlight hole, and they need to be lower in the chassis.
Archive Gatekeeper
Yep, same shaft bearings. Fore, aft, up, down. PITA. rounded end forwards.
