replace seat switch?
Each switch is separate ...they come with the wire harness attached and need to be popped out of the housing after the trim bezel is removed. You can avoid removing the seat by cutting and splicing the wires with the seat in the car. And ANY of the 4 way switches can be used as a replacement since the harnesses are the only difference.
Received 1,638 Likes
Splicing harnesses is The Devil's Work.
Take the extra 15 minutes and remove the seat so that you can UNPLUG the switch pigtail harness.
Basic Sponsor
You need to know if you have memory seats or not. The switches are different.
Memory seat switches are way cheaper.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
