Fuel pump replacement 1st year 928
Has anyone used a Walbro 255 lph in line universal fuel pump as a replacement successfully? I recently acquired a 1st year 78 5spd car that has been parked in a barn since 1995 after both fuel pumps quit. I have a new Walbro GSL 392 255 lph pump left over from a long gone project, and I'm wondering if it'll work fine in this application. Plenty of flow and volume for this engine, but will it overwhelm the fuel system? Do I really need to replace both pump or will 1 suffice? Anyone have a good cost effective replacement source?
If the Walbro can be plumbed in and mounted properly (and has a check valve), and it can deliver required pressure (75psi for CIS) it should work. Delivery rate shouldnt be an issue. Might be a bit messy around the second pump location? My CIS car had an S4 pump when I got it, and it worked fine in 120F temps for years.
jp 83 Euro S AT 57k
jp 83 Euro S AT 57k
