Shock Blowout @ 928sRus - August Special
Basic Sponsor
Full set of Boge (Sachs) stock shocks $550
Full set of Koni Adjustable shocks $620
Full set of Bilstein shocks $928
Limited to orders received in August 2017.
Email orders (or phone) only (please do not post your order on this thread unless you follow up with an email)
Administrator - "Tyson"
I like a firm ride, Lorelei doesn't.
Has anyone put Koni's with sport springs on the left side and Bilstein's on the right with standard springs?
I think that my be the perfect solution.
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Fuse 24 Assassin
Fuse 24 Assassin
Bilsteins yield a more sporty right thanks to firming the suspension up. Boge is more of a 'comfort' shock. They are fairly durable and the OE replacement recommended by Porsche.
FWIW, I just removed a set of Bilsteins yesterday as the owner hated the rough, unforgiving ride they provided. Put on Boge's and he's the happiest man in Texas right now.
Person preference for me is Koni's.
Fuse 24 Assassin
Fuse 24 Assassin
I hate to say it but I may stay Boge given how bad the roads in CA are nowadays. At the most I may toss on a set of Eibachs at the time of replacement to firm it up during hard turning.
The other plus to the Bilstein's is they are rebuildable. As long as you don't need replacement hard parts they will rebuild starting at $95/shock. Hard parts (new rod, etc.) are quite reasonable in the grand scheme.
Mike
p.s. if you scroll to the bottom of the page you can switch the version
Mike
I go back and forth between getting the Bilsteins, Konis, or sticking with Boge. The Boge on my car are the first replacement set and probably have about 50-60K miles on them. I find the ride a bit soft and slightly floaty in the rear going over abrupt bridge or pavement seams. Not bad, but definitely not sporty. Would a new set of Boge be more controlled than 50K/10+ year Boge?
In the long run the Bilsteins will be the cheapest option as you can rebuild them as stated above.
They will also custom fab parts for your shocks if they are NLA like for a full set of gold bodied Bilsteins.
I use them on my 81 with stock springs and 18 inch rims and they are firm but by no means uncomfortable.
I just need to wait until after Werks Reunion to get a set for my 89. Can't max my cards just yet
Chronic Tool Dropper
I believe that Koni will rebuild also. And Konis are adjustable to what firmness you like. Most folk set it once and forget it, BUT it is possible to adjust in situ.
