78 Euro Vin# question
hi all,
i wanted to see if you guys could help me with a vin# I was looking at. It's a 5 speed 1978 with side markers behind the front wheels. I found this number on an old CA smog plate on the back of the drivers door. It is 92881021xx. It is not adding up to the info listed online. Thanks for your time.
That looks like the correct 10 digit number. Mine for example is
9288100622.
The 1 means it's a euro) instead of 2 for US), then the 0622 shows it's #622.
Yours would be #21xx.
I believe I'm correct but others may chime in
9288100622.
I believe you may be thinking of US models when you mention those numbers, vins 1200 and below.
There is a ROW (Rest Of World/euro) vin # in the 928 oc registry a few hundred higher than yours. So, your number would definitely fall within the spectrum.
Post some pictures when you get a chance.
Brian.
Brian.
Thanks Air tek! What's the going rate for one of these that's all there but needs paint interior but runs? Ha I'm justifying in my head if I need to even jump into one of these? A ballpark could sure help. Thanks so much.
Is this the red one in Beverly Hills?
The one with the aftermarket front & rear bumpers?
