928 Forum 1978-1995
Sponsored by: 928 Specialists
Severe tow out issue
Old 07-25-2017, 01:09 AM
OTR18WHEELER
You can call me Otis
OTR18WHEELER's Avatar
Default Severe tow out issue
Old 07-25-2017, 01:18 AM
jcorenman
jcorenman's Avatar
OUCH!! And you told them not to lift it before doing the alignment !
Seriously, I hope you are OK (underwear aside) and there is no other damage. Looks like the boot was torn, maybe dirt got in??
Old 07-25-2017, 01:46 AM
terry gt
terry gt's Avatar
early cars hang from aluminum ball joints
PORSCHE should have recalled , and dealt with this design flaw
Old 07-25-2017, 02:16 AM
OTR18WHEELER
Unfortunate, but I feel really lucky, this could've been real bad, 6 miles earlier I was on the interstate.
I had noticed some Orange dust on the rim a few days ago but thought it was brake dust.
luckily this happened while at idle speed covering the brake.
Old 07-25-2017, 02:58 AM
The Forgotten On
The Forgotten On's Avatar
This usually happens when your are making tight turns and putting stress onto the ball joints, generally this happens at low speeds in parking lots.
Swap to steel joints and their eccentrics as soon as you can when you do the repair.
Old 07-25-2017, 03:08 AM
Kiwi'79
Kiwi'79's Avatar
Sheeesh!!! Glad you ok, bet that gave you a fright!!!
Old 07-25-2017, 05:47 AM
The Deputy
The Deputy's Avatar
About a thousand percent sure that that is a steel ball joint. But, even they will wearout...obviously.
Glad you weren't hurt Ferris...and it doesn't look like much damage otherwise.
Brian.
Old 07-25-2017, 03:16 PM
OTR18WHEELER
Minimal damage to the fender, the metal air deflector was damaged during the flat bed operation.
the tow bill was $75, to go around the block.
Old 07-25-2017, 03:26 PM
Landseer
Landseer's Avatar
What say the magnet when applied to the joint body?
Old 07-25-2017, 04:46 PM
Wisconsin Joe
Wisconsin Joe's Avatar
It's an 85 US (S3) IIRC. Should be steel.
Old 07-25-2017, 05:27 PM
SeanR
SeanR's Avatar
Look at the amount of rush on that ball. Geezus.
Old 07-25-2017, 07:10 PM
OTR18WHEELER
yeah, it's steel, . I have to admit that I knew before hand the uppers and lowers were going to be replaced soon.
It was squeaking pretty bad, and steering was feeling tight.
wifey took the tow bill receipt to the insurance office today and they cut her a reimbursement check on the spot.
I straightened out the fender and put on a used ball joint for temporary service untill I can order a new upper rebuild kit and two new lowers.
took it for a test drive, I guessed with the eccentric washers, but it seems to ride pretty good.
Old 07-25-2017, 07:35 PM
AirtekHVAC
AirtekHVAC's Avatar
Wow! Glad all was ok my friend.
Old 07-25-2017, 08:01 PM
SeanR
SeanR's Avatar
Don't waste your time on a rebuild "kit", get the rebuilt arms from Mark A.
Old 07-25-2017, 09:41 PM
Dave928S
Dave928S's Avatar
^^ what Sean said.
I think your car is trying to tell you something Otis ..... HELP !!!!
Quick Reply: Severe tow out issue
