Understanding the source of the ticking sound is important for the failure analysis. 1 for 2 crank revolutions: gear issue. Different rate: chain anomaly running over gears and/or pads. On a bicycle, a stiff link or a link pin half released makes a telltale noise. Something that changes the length of the chain will mean it will be alternately loose and tight as it goes around.
Official Bay Area Patriot Fuse 24 Assassin Rennlist Member
At what mileage are your tensioners and pads going bang? I am at 160,000 on original pads. I am not proud of the fact I haven't changed them since doing a valve cover reseal, but I literally had only about 1mm wear.
I don't know how you're keeping it together Landseer, but I would be pitching the "LS3 swap is strategically cheaper" to my wife if I were in the same predicament.
My 89 has 194K miles on the original pads. I guess I need to add this to the to do list of items to do when I bite the bullet and do a top end refresh.
These failures are starting to sound like RPM vs wear issues. 944S, S2s and 968s wear their chain tensioner pads out faster because their motors are usually wound up past 2500-3000 RPM. For the 928, most cars' pads may not be having high failure rates because higher RPMs are usually not attained due to the engine's torque, or how people drive it (i.e. cruising or freeway in a tall gear)
