Freezing temperatures, lack of antifreeze, cracked blocks, and idiots
Been selling Twinkies on Ebay,
have some extra cash right now.
I used the full strength stuff. Planning to head out there this fall...
Erik, are you crazy?
You have a nice looking 928 with a EURO S motor in it and you are leaving it covered over the dirt/soil
Get that car off the dirt/soil!!! The humidity will corrode everything... Ask me how I know about these things...
All the Idahoans I met, said to invite more Texans (cuz they run off the Californians...)
I have overwintered her outside before, in a wet climate. I think she will be OK. But in looking at that pic of mine, I may add a 3rd layer to her to really button her up. Another tarp that seals tight down to the ground mostly. But in my experience, you do want some airflow under the chassis though.
This is a pic of an old Suburban that is stored outside in NORCAL. I use it exactly once a year, and for 10 years so far, it fires up every time!
But, no snow at that location.
That and be sure to add fuel stabilizer, and run it for a bit to make sure it gets into the fuel lines.
1 Post
Living in a seriously cold place, combined with way too many vehicles and not always keeping track of what is what, one thing I have learned is that there is a real difference between a freeze up with water, and a freeze up with too little antifreeze. Water freeze ups are almost always expensive, too little antifreeze can be inconvenient but is generally not expensive. When the weak coolant freezes you end up with slurpie, this allows the pressure to be distributed evenly. If the pressure gets too high the hoses usually take the hit if the pressure relief in the fill cap doesn't work. Port in the cap doesn't flow slurpie well.
I can't say at what point it changes from low refrigerant to water, but we would leave farm equipment that wasn't used in the winter with 30% and at that level we didn't have an issue.
We do on occasion get to a real before wind chill -40 so that is as much as a test as you're likely to see.
I've taken to putting a tarp under my cars when I park them for storage, even in my winter storage tent.
I think that my location won't see that. They get only about 3-4' of snow there, and is a relatively arid place otherwise. Maybe the melting snow could be an issue? My Suburban still looks fine underneath after 10 years, but it is taller and has better ventilation.
Pat: re the mouse bait as an attractant... it makes sense. That it lures them in to breed and make pups before they die. With the Suburban, it was a stinking dead rat mess every year before I incorporated coolant traps into the rodent defenses.
Re: the 30% slurpie, I have heard that elsewhere, but kind of thought it was made up... I figured the coolant was either frozen, or not. You have actually seen a partially frozen slurpie coolant mix? Maybe I should have left the radiator cap off?
Thanks everyone!
The slurpee business is real. A pure substance freezes at a single temperature. Adding something to it (the "solute") changes this melting/solidification point to a solidification range. Metallurgists can take a phase diagram and explain that the first stuff to freeze has a low solute content, and the last to freeze has a high solute content. Depending on the two substances, the last stuff may be a "eutectic", which then freezes out at the same temperature. Otherwise, solidification will be continuous, with liquid present until the last bit freezes. This liquid can ooze out, in principle, and relieve the pressure. In a radiator, it can ooze into the hoses - but maybe not if the hoses freeze solid first. We're talking about very high pressure here, and for ice an elevated temperature where it can undergo "creep" deformation, glacier-like, as long as it has some place to go and can take its time.
Everything freezing at once is the worst case for handling the increase in volume of ice upon solidification (a weird property of water). There is little opportunity for liquid to ooze out somewhere to relieve the pressure. Pure water bad; a mixture that goes to the eutectic less bad; a mixture without the eutectic good. There is a eutectic in the water-glycol system - car people know it well as the mix with the lowest freezing point, but since it all freezes at a single point, it might be risky in Antarctica.
Water corresponds to the left edge of this diagram - the freezing point is clear at 0°C. Going to the right means added antifreeze. The solidification start temperature drops, and the region below that is where you get the slurpee. The eutectic is at about 65% glycol. Metallurgists live and die according to phase diagrams like this. Geologists, too. (Edit: this phase diagram is simplified, not showing detail for the two pure materials that makes it clear they freeze without any slurpee stuff.)
Having grown up in Montana and spent more than my share of time in the woods... I never did see a Porsche used to access those beautiful and wild places.... would have been something to see.
Captain Obvious
Super User
Super User
Since you have to go and add more antifreeze, I would park the car on a tarp to seal it from ground moisture. Next to grass, dirt is the worst place to park over when storing a car.
Have to ask, why bother keeping a nice vehicle if not going to store it with a better eye toward it's condition? I get why a truck used out in backwoods might not get a 'while glove' treatment, but the 928?
