Low/Rough Idle
Low/Rough Idle
So my 82 924 N/A has been running great for the past week and a half, until it just recently rained. I'm suspecting an ignition component got wet and is causing my car to idle very low, about 500-600 rpms. It idles there very steadily, it isn't fluctuating or popping at all and the throttle response is fairly decent. Where should I look first?
Will do, I've checked the entire ignition system and still no dice. That's definitely my next move. The cap and rotor are still good, less than a year old. Let te vacuum leak hunting begin
Hi,
I used to have 1978 924 - back in High school in the late 80s- please make sure the hood is not shorting the distributor on the top - My front hood was misaligned when I ran into a table - I forgot my foot was on the clutch and first gear and it lunged when I lifted my foot off the clutch... not happy...
