924s Rebuild
924s Rebuild
Ok, Ok,
Since it is so dead I'll post this. Any input and recommendations will be much appreciated. I munched my little daily driver last year. Insurance company totalled it, but I kept it. Frame is unbent, but front brackets are torqued. I'm starting from the ground up. Plan is to upgrade suspension with Konis, Turbo struts/Brakes/Anti-sway bars. Then I want to rebuild the engine to '88 specs with the higher compresion ratio/HP, including a new intake system/headers/high-flow cat/muffler/FPR/Turbo injectors. While I'm piecing that together I'll get the body reworked to include shave side lights, 968 side mirrors, rear and front valence. One thing I was wondering is if a 968 DME and AFM can be used on a 944 engine. The reason is the 968 AFM is a hot wire vice the old flapper. Anyone Know? Thanks
