924 and 931 Forum 1976-1988
79 924 Single Fuel Pump Conversion
Old 07-05-2016, 08:15 PM
Jott5555
3rd Gear
Jott5555's Avatar
Default 79 924 Single Fuel Pump Conversion
I recently Aquired a 79 924, It has been sitting for several years, I went to drain the tank and clean the fuel pump and one of the Nuts on the external pump broke off,
So Before I go throwing parts at it, I want to know what is needed to convert it to a single external pump from the current 2 pump setup.
From my understanding a in tank strainer (928 201 081 04) is used to replace the in tank pump, Then a Walbro GCL604-1 Or the better priced AUTOBEST F4170
Is there also need for a check valve somewhere?
Thank you, I have a Haynes coming later this week to help with testing, Even after this fuel pump issue is finished I need to figure out why there is no spark,
Thank you!
Quick Reply: 79 924 Single Fuel Pump Conversion
