How to fit Late caster block to steel control arms?
Hey guys, have anyone been able to fit a late offset caster block to the steel control arms ? I would like to use a rubber bushing on the end of the arm, not poly, delrin, etc, not the fairly mushy factory bushing the steel arms used.
I'm guessing that the ID of the steel sleeve in the caster block is larger than the OD of the peg on the end of the steel control arm, but hard to tell from the pictures.
Perhaps one of the other can ge sleeved so it all fits together as a solid press-fit ?
Just curious if this has been tried or thoughts on it ?
Thanks !
Thanks !
