924 and 931 Forum 1976-1988
Difference betw. 924 & 944T rotor?
Old 11-22-2002 | 03:37 PM
911pcars's Avatar
911pcars
Post Difference betw. 924 & 944T rotor?
Notwithstanding there are wheel/tire/body interference fitment issues when upgrading to these rotors, what is the actual physical difference between them? Diameter, thickness, hub offset? Anyone have comparison pics?
Thanks,
Sherwood
Old 11-22-2002 | 03:39 PM
911pcars's Avatar
911pcars
Post
To be more specific, I'm referring to the '86 944 Turbo rotors, but later year rotor information would be welcome as well.
Sherwood
Old 11-24-2002 | 08:35 PM
tifosiman's Avatar
tifosiman
Post
I think I am a little confused by your question. If you are planning on using the 951 rotors and not upgrading the calipers, then this won't work.
What year is your 924, and what is the offset?
Tifo
Old 11-24-2002 | 09:41 PM
911pcars's Avatar
911pcars
Post
Nope, just my obtuse method of finding out if a '86 944 Turbo rotor will fit on a 911 (911 and 924 rotors are the same, I believe). The "correct" caliper is an independent but related issue in this case (one of the 4-piston front or rear Brembos). Do you know the rotor dimensions by any chance?
Thanks,
Sherwood
Quick Reply: Difference betw. 924 & 944T rotor?
