Parting out 2 '86's
#106
RJB,
I have one tan(bottom) dash and one black. I peeled the vinyll off the top of the tan dash and saw the foam padding was in good shape. My plan is to put a coverlay cover on it and it should be as good as new but I have not done it yet. The all black dash suffers from some cracking on the top.
#114
Dan:
This cargo cover has a very strong spring with great retractability and both hooks firmly attached. It also has a dimple where I guess something may have hit it. Where the dimple is (area about the size of a quarter), the covering has peeled off. Here's a picture.
#115
Stuff I'm looking for:
Black floor mats, good condition
Center console armrest/cassette box, good condition (color unimportant)
Rear luggage cover (Black) OR plastic end pieces in any color
Driver’s seat belt inside ‘L’ bracket with receptacle
Trim cover piece that cover the screws where the dash plastic trim is between the driver’s vent and headlight switch.
Black trim plugs from header panel
Black seatbelt trim piece from upper passenger side B pillar
Complete rear wiper assembly with switch.
Let me know if you turn any of this stuff up. PM or jpetty@tarantella.com
Thanks,
jp
Thanks,
jp
#120
I'm looking for the following pieces:
1.) The piece by the headlight switch that the dash light dimmer snaps into;
2.) An ashtray light socket with 3-4" of wire on it;
3.) 6 tie wraps (type that holds the wiring harness across the firewall);
4.) One hole plug for the console;
5.) A good looking cubby hole for the console.
Anybody else reading this; I'm looking for all four (good) bugundy door panels for my '86 951 to repair a previous hack speaker install.
Thanks -
Doug
Thanks -
Doug
