Tire pressure...
look in the gas tank cap cover, in the early cars its 29 front 36 rear, thats what i use and it works pretty well as far as neutral balance to a little oversteer.
-Michael-
-Michael-
Well that's the recommended pressure of OEM tires 20 years ago, so the optimal values are probably a little different depending on the actual tires on the car now. But going with a ratio like that should be perfectly fine for the street.
check archives on this, there was a good thread a while ago about this, many postings of different pressures. I prefer about +2-3 front and rear, it really depends on tire as mentioned and taste I think. It's fun to try different pressures and see how it changes handling. Homework, but the fun kind.
