[1988 2.5 N/A] What are the connection tips on each of the rubber fuel line hoses?
I want to replace rubber fuel lines on my 1988 2.5 N/A. Near the place where I live is the company Tubes International that can make fuel lines for me, but I need to know what I should order.
I know that:
But I don't know which hose is which, I mean which is closer to the front of the car, however if we stick to the ethymology in the bullet points this doesn't matter because I won't install these hoses.
Main question:
The biggest problem is that don't know what kind of connection tips should be at the both ends of each hose thus I can't order: https://s23.postimg.org/wjcz9zn8r/IM...311_153154.jpg
Here is how the hoses manufactured by them look like, but the person who ordered them ordered them much too long(80cm) and doesn't remember what kind of connectors are on the ends.
Can you help me please?
I know that:
- One hose has 10mm inner diameter Let's call this hose "NO.1"
- The other one has 8mm inner diamater. Let's call this hose "NO.2"
- Both are in Silco fire sleeve
Main question:
![](http://924.pl/forum/attachments/prze[11019].jpg)
https://www.lindseyracing.com/LR/Par...FUELLINES.html
Scroll down and you'll see, "10mm & 8mm to -6 JIC Steel Compression Fittings"
