recall fuel line fix
the sfr kit gives you the lines that go from the send and return pipes coming up in the wheel well sort of area to the fuel regulator and damper. it doesn't give you the short line that comes out of one the damper/regulator(i've forgotten which, it's the front-most one) and goes, well, somewhere. it is this short line, though, which i believe was the subject of the recall.
but i think the replacement part is relatively cheap, though it might be a crimp fitting.
-A
-A
