Help me undertand early Sachs insert please
Please help me understand what I'm dealing with here.
Subject: early strut insert (SACHS BOGE).
Situation: I'm looking to stiffen my ride a bit so today I started the process of replacing the standard inserts with sport inserts. I have 8 month old Sachs front struts on my car that I was planning on selling to another hombre on this forum, but am questioning the ethics of that now.
I remove the spring hat & spring. Undo the strut cartridge cap easily with no drama. Didn't even have to touch the alignment cam-bolts! Woohoo!
Then I pull the strut insert straight up out of the tube and to my surpise the rod & piston and tube came out of the tube separately with the hydraulic fluid coming out.
That seems wrong to me, as the advertisements for the strut inserts show them together, I am assuming the buyer doesn't have to assembly & "bleed" them. Correct?
Is this normal?
Is this normal?
Not normal. The inserts are one piece, no bleeding. Just pour some oil into the tube first for heat transfer.
Are you sure those are Sachs? I installed Super Touring inserts in my 83 and they were black and welded together (I believe, it was 3 1/2 years ago when I did them).
Not normal. The inserts are one piece, no bleeding. Just pour some oil into the tube first for heat transfer...Are you sure those are Sachs? I installed Super Touring inserts in my 83 and they were black and welded together (I believe, it was 3 1/2 years ago when I did them).
I can only assume if you buy the complete Sachs strut it is build without an insert, when it comes time to rebuild Sachs supplies a sealed insert to drop in.
