fuel line leak
fuel line leak
i have a leak in the fuel line that goes from my fuel pump to the filter it is just before the metle conecter that gos from the ruber line to the metle line into the fuel filter. i was able to make a temperary fix with a fuel line repare kit but i think it is prudent to replace the line. my question is where would i find a new line and dous anybody have any sugestions for replacing it,, other then empty the tank first....
Factory replacement part is available from your dealer. I think Paragon has it too if you e-mail them and ask. I replaced mine a year ago because it started to leak at the crimp that connects the banjo fitting to the hose.
I think the part number is 944 356 041 07 and it is not cheap because of that big *** fitting on the pump side. Make sure you replace the crush washers while your at it and you may as well replace the check valve too.
You better check the part number I gave you as I'm going by receipts and not the PET on that one.
