I must have Jinxed my wipers!?
Two hours?? Geez. I figured it was an unbolt, unplug type fix? What is the difficulty?? "Mein" car is outside tonight (in the rain), so I can't pop the hood and see where the motor is located in there...
Sorry, Im not good a spelling english, however since I have been taking pronunciation classes for over 2 years I can speak it very well. Moving on, that was exactly my point, the Wiper motor pretty much is an un bolt, un plug type deal. So if you dont do it yourself make sure you get a quote first I hate to see you getting ripped off again.
Christian
Christian
Just messing with you Christian! You spell in English WAY better than I spell in German!
Thanks for the advice--I'm getting list approval before I get ANYTHING done by a mechanic from now on!
Post 85.5 wiper motor replacements are a PITA!
You have to remove the air box to get the whole assembly out.
BUT!
You don't have to take the whole assembly out to replace the motor!
If you unbolt the two through shafts the blades are on and the bracket mount then kind of push the pivots down and pull the bracket up a little you can get to the motor.
Be darn careful NOT to crack the windshield!
Once the replacement motor is in and before you hook it to the linkage, run the wipers and let them park. Then put the primary crank arm on loosely in it's parked position (you did make a note of that when you took it apart) and put the wiper blades back on in their parked possition. Hint: The primary crank arm and it's immediate link should be straight across.
BUT!
OK so I'm hijacking this thread a bit. Speaking of wipers, so what's the deal when they won't automatically return to their "rest" position when I switch them off. This is something new that started happening yesterday what I happened to get caught in the rain. I need to switch off my windshield wipers exactly when they reach the bottom of the windshield.
