Smoking Tire - 944 Turbo One Take
You should check out Matt Farah. There's a clear likeness. He's on the Drive Youtube channel.
Modded! But not too much yet.
K27/6 ported, 55lb injectors, max chips, MBC, 3' Exhaust, all new hoses/lines/etc, Bosch HV pump, usual first round power mods. Stock AFM.
KW V3 coils, Tarret sway bars, 16x8" square wheels set up.
Somehow made 353WHP on a mustang dyno last week while chasing down a loss of power issue after putting in potentially bad gas. Pulled 340WHP at 6000 first run, second run bogged, 3rd run made 353. Draining tank this week to change in tank filter and blow out lines, as well as install rail gauge and checking flow. AFRs were all over the place.
May be TPS failed coincidentally at the time, or bad ground. Also replaced 3Bar FPR and damper.
Glad it happened after the One Take shoot!
Lols...I had to look at that a minute...
Matt Farah (host of TST) has said that he looks to do a stock, a lightly modified version, and a highly modified version of a car. So hopefully two more people can step up and we'll see even more 944 videos coming out.
He can come and use mine as a lightly modded version.
This will be interesting to watch. I don't care for Matt Farah....but worth dealing with to hear his feedback on your car.
My car has the exact same list of modifications. Sweet!
