Need 944 924S Cylinder Head
Picked up an 1988 924S with bent valves so I was told. I will be opening up the engine and seeing what is broken. I will probably need a used head with good valves. You can email me seb928s@ij.net or leave a message about your cylinder head and price,shipping (33710 St.Petesrburg Florida), and condition.
THanks
THanks
8th Gear
Why go to the trouble to remove the head and then put someone elses troubles back on with a used head. Get the head refurbished. A good shop can fix the valves better than new, do some minor flow work, make sure the valve guides and seals are NEW, and give you some peace of mind that what you put back on is bulletproof. There might even be a savings over buying a new(used) head.
