Klankklank... Damn.. Engine died..
Speaking of engine failures, I have a related (sort of) question. I'm looking at a S2 with 124k miles. How many more miles can I expect the engine to last, providing that I take proper care of it with regular oil changes, and I drive it "enthusiastically" but not "stupidly." ? And yeah, I know that "things can happen at any time" but in usual circumstances, how long is the S2 engine good for before I have to have a top end job done, etc.? Also, what kind of repair/replacement costs would I be looking at if the worst does happen to my (possibly) S2?
Reason I ask, I had a '78 Ferrari 308gt4, and talk about expen$ive costs, the water pump was $800. USD. So, I don't want to get caught in the same game again. I know Porsche costs won't be THAT stratospheric, but the other alternative I'm looking at is a 1989 Mazda RX7 GTUs. Engine replacement on that would cost (as far as I've seen so far, at least) around $2500, I think. How would that compare to a Porsche 944S2 engine replacement?
Thanks, everyone. I really "want" the Porsche, but I've got to be kind of realistic about this, too.
Best regards,
Tom Reynolds
Hereford, AZ
Best regards,
Tom Reynolds
Hereford, AZ
Bad luck m8..
If you turned her off pretty quick chances are all she needs is main bearings and crank thrust bearings( probably part of one of the main brgs I don't know on this lump). Would be worth doing the big end brgs at same time. Obviously check small end too but should have been uneffected
You should be able to change all these brgs in situ by just dropping the sump without tearing off head which saves lots of time and expense.
Just pull the main bearing housings and push the cylinder up the bore to release the top bearing shells. Slide the top bearings round the cranck and they drop out put new in the same way.
I have done this on lots of motors to get a simple cheap fix but not certain if it is possible to change thrust bearings on this lump in this manner.
best of luck
best of luck
