eccentric bolt adjustment?
how much of a pain in the *** is it to adjust the eccentric bolts to lower the back end? Also how low can you abjust the rear by this process, anybody got pics of a lowered rear end done this way?
An impact wrench is the only way to go for this job. The bolts you have to loosen to be able to move the eccentric are really on there. With the use of an impact the job is over in about an hour.
