Low oil pressure at idle and start / wavering idle when warm, any new data?
Old 10-25-2003, 10:18 AM
schlag
schlag's Avatar
Originally posted by Kevin Baker
Schlag, mine's done 100%. I just replaced the little o-ring that goes at the end of the oprv. Check in the 1999 technical reference manual, bulliten #3 it will have the part #'s for the o-ring, and the crush washer that you need. My oprv turned out to be OK, the o-ring had just disintegrated. Part # 944-107-935-01 should be the o-ring for the post 87 cars.
I'll try it. Thanks!
Old 10-25-2003, 11:15 AM
Granite 944
Granite 944's Avatar
I agree with Kevin completly. Make sure your oprv is not corroded up, the alignment thru the oil cooler is good, and a new o-ring on it. Do look at the bulletin he refers to, all will become perfectly clear then.
Just for comparison purposes, my engine is the '85/2, (with the shorter) one peice OPRV. I have gone thru and cleaned all electrical connections and grounds. At cold startup, oil pressure immediately shoots up to 5 bar (within a split second, no throttle up). After engine is fully warmed up, engine idle pressure is at no lower than 2 bar. Oil pressure responds instantly to throttle. All pressure readings on gage are very steady/stable.
Old 10-26-2003, 12:59 AM
Kevin Baker
Kevin Baker's Avatar
Dave, that's great news. Look forward to meeting you at a "greasesling" event.
Quick Reply: Low oil pressure at idle and start / wavering idle when warm, any new data?
