951 Alternator Harness Routing
Need to know how the harness is supposed to be threaded down to the starter. I have it clipped into the tabs on the top of the heat shield already.
Bonus points for a picture or two!
It runs back past the AOS then to a c-clamp that mounts to a stud on the clutch housing. From there it goes down past the clutch slave cylinder to another c-clamp and then to the starter. Going by memory here so someone correct me if I'm wrong lol.
Ya I think that's right. Starting at the alternator, the harness runs over the BS housing, and over the AOS. Then it tees, the harness with the fat cable and the red wire goes down the driver side of the bellhousing, and the harness with the red and blue wires goes to the firewall and connects behind the brake booster with a white plastic connector.
