Window Problem
![Exclamation](https://rennlist.com/forums/images/icons/icon4.gif)
well,my passenger window stopped working recently,almost exactly when i got my a/c fix.i tested the motor and it would go up but not down and when i put everything back it doesnt work again!i suspecting the switch but i tested it with a working switch and it still doesn't work.what could be the problem?thanx in advance
Nerd Herder
I know it sounds simple.. did you check the fuse? It may have blown when the AC was hooked back up..
On which car?- New or old window switches?
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
I need to take apart my passenger door on my 928. Something is scratching my tint.
Call me if you want to get together and tear our cars apart.
Check your PM for my cell number.
James
James
How did you check the motor?
These are DC (Direct Current) motors. To reverse the direction you reverse the leads. So when you say you tested the motor directly and it only went one way...
If the motor works one way it works both ways. The problem is with the switch. Either the one that directly controls the window on the passenger side or the remote switch on the drivers door. Or both.
just an update.i know the window motor and switch worked because i tried it on the drivers side and they both work properly.so now i know i have a lose/grounded wire somewhere.btw,does anyone have a window wiring diagram?or where the window wires go(like dme or klr?)thanx
