Needed: Lighted lock knob
The factory alarm with blinking LED's appears to blink the LED's when you are in the car and driving and use the console mounted switch to lock the doors.
I have picked up two used blinking LED ***** for the 944 - again from Porschapart.com and they work perfectly. Door panel removal is required to install them.
I also noticed that the voltage sent to the LED "box" is 12 volts - so maybe it's easy to "steal" power from elsewhere in the door (would have to be a constant source - not ignition dependent) and just install these lighted *****. Even if they flash ALL THE TIME - does it matter? It'll appear that your alarm is always on - and how's that a bad thing?
I got a digital camara yesterday - I'll get pics of these parts up later today.
RK
PS. I think I now have a fully funtioning factory alarm in my S2!
RK
I'd rather have them only be on when I'm out & away from the car- think it might get annoying inside THE car, but I could deal w/it- I just came to the conclusion that it would probably be a simpler install to just wire to a direct switch & just remember to hit it when needed...
BTW- do the regular 944 lock diodes have a little rectangular box w/plug-in end on it, wired to them, like the 968?
There appear to ber two types - one for the S2 and Turbos (late model - 90 and 91??) and then for the 968's which are longer.
This is a pic of a 944 S2 version - WITHOUT the conencting rod. I think it's the rod that's actually a dif length.
The LED ***** just screw off the top - so you could buy either and screw the LED **** top onto your exiting rods if needed.
RK
RK
RK
RK
