Manual window conversion...
#76
Originally Posted by guns951
Hey can't someone make a mold (bare) of the inner door then produce a carbon fiber door panel with no cut outs? then if you want window cranks (custom) you can cut holes where you need them? I'm talking with the arm rest removed (on the door not center console) and with a manual window mod in mind. I would totally spend as much as required for this kind of mod.....
#78
For 85.5+ 944s, here are the NOS parts/prices (as of April 2005) from Sunset. Likely arrive from Germany 4-6 weeks as these are euro-spec pieces. Prices may have changed since April.
944.537.041.00 Manual window arm $113.15
944.537.042.00 Manual window arm $141.45
944.555.057.01 *3DL* (black) Window crank 2 @ $11.39 ea
111.837.595A *01C* (black) Window crank base 2 @ .76 ea
944.537.589.00 Guide rail (optional) 2 @ $6.50 ea
Close to $300 in parts (not including shipping) for NOS pieces.
#79
there is also a crank base gasket 411.837.447 for about .75/ea. Keeps the base from wearing against the door panel. Prices have changed slightly since April, but not by too much.
[edit] my mistake. The crank base gasket is not required except for those using old 924 door panels (early 944, 924S retrofit)
#81
Sure thing. I need some more time to locate the later model lifters and cranks, but the 924s and early 944 stuff is up:
http://www.paragon-products.com/prod...window-kit.htm
It is my understanding that you can use the early model stuff on the late models with a little "fitting". I believe there have been a few here who have done this, so the search tool may find something useful.
Good Luck!
Good Luck!
#83
all parts and prices for early and late models now available
#87
Body, Mechanical and Trim... or, follow this link:
